need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,817 Status: Offline |
Post #1276
friday the 1st and wednesday the 13th are the only dates I can see so far for cadwell.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 5th Jun 2017 at 15:40
Seasoned Pro Location: DoncastAAAAARGH Registered: 13 Jan 2008 Posts: 4,637 Status: Offline |
Post #1277
Ive seen one on Wednesday the 8th through javelin.It seems like it's too far in advance for them to be displayed online unless it's just like that on my mobile ________________________________________ Goldie the track car. |
Posted 5th Jun 2017 at 16:45
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Post #1278
trackdays.co.ukwednesday 6/9 £149 monday 18/9 £175 msvtrackdays.com friday 1/9 £149 wednesday 13/9 £139 javelintrackdays.co.uk wednesday 6/9 £149 is what i can find at the moment |
Posted 5th Jun 2017 at 18:29
cully
Post #1279
prism7guy wrote: Ive seen one on Wednesday the 8th through javelin. It seems like it's too far in advance for them to be displayed online unless it's just like that on my mobile Fri 8 Sep Day Cadwell Park General Car Testing Race Cars Only |
Posted 5th Jun 2017 at 18:32
jeffers
Forum Admin Location: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Post #1280
I'm up for cadwell, September time would be spot on as well...________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Posted 7th Jun 2017 at 07:22
RetroPug
Post #1281
Day666 wrote: my rear spoiler seeing as it puts 180kgs of weight down on the rear at 120 mph How have you measured that out of interest? Using spring rates and measuring the change in ride height at 120mph with a potentiometer? ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Posted 7th Jun 2017 at 20:25
Seasoned Pro Location: Bristol Registered: 20 Apr 2013 Posts: 5,209 Status: Offline |
Post #1282
RetroPug wrote: Day666 wrote: my rear spoiler seeing as it puts 180kgs of weight down on the rear at 120 mph How have you measured that out of interest? Using spring rates and measuring the change in ride height at 120mph with a potentiometer? By the guy in France that made it & races with one & sells them ...I don't have a clue ...the info was needed to give Black Art Design suspension my corner weight details inc TB size / Arb size & anything that could or would affect the car at speed & John from BLack Art worked his magic as per normal |
Posted 7th Jun 2017 at 21:33
cj-gti6
Senior User Location: Barnsley Registered: 09 May 2011 Posts: 799 Status: Offline |
Post #1283
pugheaven wrote: Me, you, ross and Chris should see what deal we could get Agreed. ________________________________________ 99/S Carbon Gti-5 |
Posted 8th Jun 2017 at 11:49
Post #1284
I'm sure we all like pictures as I do so small unusual update for me Strange change of plan that I've never really thought of or really wanted to do but kind of happened by accident...... ....I mean it's liking tattoos on others but wouldn't want one yourself Right here's the story ...Tony Palfrey of Maxi Motorsport contacted me & asked if I would be interested in a front 50mm wider each side French made bumper for my car ?....not the Maxi 75mm one.... he had this in stock & it was getting in his way he said.....it got me thinking & not only does it fit (Gnrlee = David Warrens) Splitter I have but it directs air & most important saves a fair bit of weight ......I'll weigh it soon unless One of you on here has against a standard front bumper ? Then Tony says how about some French made Kevlar Carbon front wings to match your doors ?......ooh I'm thinking .....but I said I don't want to go wide arch really but this will enable me to run better selection of tyres including going to 18s on the front & dropping the profile on the side wall ???? So then I'm thinking about the rear going a little wider & I really don't want to be Dimmaing it ....so I'm playing around with the rear with Arches Tony made to modify & bolt on as I'll cut the wing about to enable me to fit 18s & bring the rear out 20-30mm without catching it & that way the tyres wont rub the inside either ... I want the front wider than the back as Tony / Colin & Wil De Claudio have all said for them it doesn't handlle as well with similar width front & back ? So I'm going to bodge to put to fine a point on it with wheel spacers front & back at mo ....Wil runs 40mm spacers on the front each side with no issues on his race car ....so we will see ...I've got converted conversion 80mm wheel studs that will take that size on the front easy So now for the pictures & Wings to follow in a few weeks or months .... Inside corner view Day666 has attached the following image: |
Posted 12th Jun 2017 at 20:41
Post #1285
Underside Day666 has attached the following image: |
Posted 12th Jun 2017 at 18:46
Post #1286
Not very interesting front view Day666 has attached the following image: |
Posted 12th Jun 2017 at 18:47
Post #1287
Inside back view Day666 has attached the following image: |
Posted 12th Jun 2017 at 18:48
Post #1288
With Gnrlees Carbon Splitter fitted just to see Sticks out about 2ft if I wanted it too but can ajust it Also I've got some blocks to lower just the splitter closer to the ground & I can go upto 5 inches so it's 1inch off the tarmac if required? So here you have it ...NOT Planned but Just kind of happened & evolved by accident ....feel free to ask or slate me with any Question about this I'm going to have the bumper on quick release ? Day666 has attached the following image: |
Posted 12th Jun 2017 at 20:43
Post #1289
We all probably know where this is going ....Satchell 406 front wide arch Ohh dear |
Posted 12th Jun 2017 at 19:01
Post #1290
40mm spacers?! fcuk that!isn't blue book maximum 20mm? I know it is for rally. colins front setup will give you the width you need, 18's may need tubbing of the arches, especially if you want width and low height. as Colin said fwd chassis setups do work well with a narrower rear track than front, Tony was going to make his 205 narrower, closer to colins, front end is identical width, i think the general philosophy is get the front nailed and the back will follow ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 12th Jun 2017 at 19:32
Post #1291
the sidewalls of a 17" are low enough, I doubt you want any less, yes the maxi's ran an 18" tyre but they were bigger than road 306's.you may not actually find a competition tyre with a low enough sidewall. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 12th Jun 2017 at 19:35
Post #1292
Corrected Mei ....Wil runs 25mm spacers max allowed each side with ET10 x15s : 8js which is 30mm each size & wider tyres for 8js .....same as I'm going to try ... or try his I've got 16s & 17s but All my rims are ET15 standard & 18s seem to be more ready available in race / Track tyres Tubbing the front 100%!....was with Tony today & he's doing his rear now ... Satchell wide 50mm front 406 setup won't happen for a while if it does ? |
Posted 12th Jun 2017 at 21:42
Cjwatson27
Post #1293
Looking forward to seeing this fitted I think I saw this kit on a website when I was reserearching dimmas ________________________________________ Old pugs don't die they just get faster |
Posted 12th Jun 2017 at 21:03
Post #1294
Cjwatson27 wrote: Looking forward to seeing this fitted I think I saw this kit on a website when I was reserearching dimmas Was it Silver 6 with orange bits ? Not having bonded blended type rear arches though only Kevlar small bolt on rear arches to just cover the wheels which will go 15-25 wider |
Posted 12th Jun 2017 at 21:31
gnrlee
Forum Admin Location: Leeds Registered: 20 Aug 2005 Posts: 8,878 Status: Offline |
Post #1295
Looking good Damo! ________________________________________ Proud Member of the ASTOR Owners Club |
Posted 13th Jun 2017 at 07:20
Cjwatson27
Post #1296
Day666 wrote: Cjwatson27 wrote: Looking forward to seeing this fitted I think I saw this kit on a website when I was reserearching dimmas Was it Silver 6 with orange bits ? Not having bonded blended type rear arches though only Kevlar small bolt on rear arches to just cover the wheels which will go 15-25 wider Yeah that's the one ________________________________________ Old pugs don't die they just get faster |
Posted 13th Jun 2017 at 07:37
Post #1297
Thank you lads .....I'm a little surprised this has happened myself to be honest ...once I've got the wings I can see what I can do with wheels & spacers first It's only 50mm each side & im hoping 25mm spacers & 8j rims -225 tyres & Et10 may fill the front arches |
Posted 13th Jun 2017 at 11:54
Post #1298
I'm sure Miles said you can do 8" on standard front arches..try ET0 and no spacers. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 13th Jun 2017 at 12:27
Cjwatson27
Post #1299
Be good to see how you get on with the spacer route________________________________________ Old pugs don't die they just get faster |
Posted 13th Jun 2017 at 12:29
Post #1300
welshpug! wrote: I'm sure Miles said you can do 8" on standard front arches.. try ET0 and no spacers. I'm running ET15 now Mei ...so with that 15mm & 8j don't think without spacers it would make up 40-50mm? Will try & see when wings come I can get custom made wheels made no issue & not silly money either |
Posted 13th Jun 2017 at 14:52
