Yes 205 Dan
Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Seasoned Pro Location: Bristol Registered: 20 Apr 2013 Posts: 5,212 Status: Offline |
Post #951
demondriverdan wrote: I'm sure I read somewhere that the knuckle works with a 306 one? Maybe it was a 205 Yes 205 Dan |
Posted 2nd Aug 2016 at 19:08
demondriverdan
Post #952
Balls. I have a couple of spare bottom bits of the column so will see if someone can make them work together________________________________________ Rallye Race Car |
Posted 2nd Aug 2016 at 19:17
Post #953
Well managed to get a absolute bargain ....£20 for a new unused Vauxhall Momo Steering boss off racer /Harry at Combe Trackday Fits my Corsa Electric Powersteering spot on ... Day666 has attached the following image: |
Posted 4th Aug 2016 at 15:14
Post #954
devere wrote: My 106 hydraulic pump is still providing resistance and feedback. Bit I run a lot of castor on the front. I would assume you will gain more feedback and resistance of you had added castor also on the corsa column. Problem with the column is the feedback gets filtered out through the big increase in friction in the UJ's and the rack/pinion itself, as they get loaded far higher than they do in a hydraulic setup ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Posted 4th Aug 2016 at 15:27
demondriverdan
Post #955
I'm thinking of getting a removable wheel boss if I change to the Corsa column, been wanting one for a while anyway________________________________________ Rallye Race Car |
Posted 4th Aug 2016 at 15:58
Post #956
Stupid question but Is it really worth all the hassle involved? What's so terrible about the standard PAS setup on a 306? Or is it all on aid of allowing the engine to rev a little bit more freely or weight saving etc....Don't really get it tbh still got standard PAS online just relocated to the sump. With decent suspension and roller wishbone bushes I have plenty of feedback feels like a go-cart and the pump is original so doesn't work overly well so steering isn't stupid light either. ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 4th Aug 2016 at 17:00
demondriverdan
Post #957
I generally like having no PAS but when it's near the end of a stint I get pretty exhausted so could do with a bit of help. Likewise it'll make driving the car around the paddock far easier________________________________________ Rallye Race Car |
Posted 4th Aug 2016 at 17:20
Post #958
Phil ..I'm not 100% convinced yet it will do what I want ?....I'm going to fit it & try it Dan ....it's the same Momo / Boss setup as I have now ..with a lifeline Quick release steering wheel ...the only difference is this fits a Vauxhall colum & my other is Peougeot Pete ...The standard PAS pulls Power & doesn't like going to 9000 rpm m8 it gets Red hot at times ....plus more room under my bonnet with both items gone ....if its Rubbish it comes off Also Pete I did have my Standard PAS on Rich W bottom sump mount |
Posted 4th Aug 2016 at 17:54
blandy
Post #959
intersted to see how you get on. Should have mine in a week or so |
Posted 4th Aug 2016 at 17:49
Post #960
blandy wrote: intersted to see how you get on. Should have mine in a week or so Mike...Yours maybe fitted before mine then |
Posted 4th Aug 2016 at 17:56
Post #961
Day666 wrote: Phil ..I'm not 100% convinced yet it will do what I want ?....I'm going to fit it & try it I can't say I'm keen on them myself, both in terms of feel and the wear and tear they cause the rack and UJ's when they're in something heavier than a sardine can and on serious tyres and geometery - everyone in the rallying side jumped on them because they're cheap and easy to fit and extolled them as the best thing since sliced bread - and then found out that the hard way. That's why I still run a hydraulic setup on the buggy. But, try it and see - everyone's setup is different. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Posted 4th Aug 2016 at 19:25
demondriverdan
Post #962
blandy wrote: intersted to see how you get on. Should have mine in a week or so What system are you going for? ________________________________________ Rallye Race Car |
Posted 4th Aug 2016 at 22:42
blandy
Post #963
Same electric column just prebuilt ready to bolt on and wire in |
Posted 5th Aug 2016 at 07:03
Post #964
blandy wrote: Same electric column just prebuilt ready to bolt on and wire in Prebuilt ?....thought they came off the car prebuilt ? |
Posted 5th Aug 2016 at 13:06
blandy
Post #965
Im under the impression they need a joint removing and welding. Ive actually got both options as ive got a complete corsa column in the garage and also looking to buy one so maybe overthinking the one i have at present so will offer it up and see lol |
Posted 5th Aug 2016 at 13:26
Post #966
blandy wrote: Im under the impression they need a joint removing and welding. Ive actually got both options as ive got a complete corsa column in the garage and also looking to buy one so maybe overthinking the one i have at present so will offer it up and see lol Was told ...fitting a Corsa B one is straightforward to a 205 ? |
Posted 5th Aug 2016 at 13:36
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,817 Status: Offline |
Post #967
same as any other conversion, they need the lower uj welding to the corsa output shaft and suitable brackets attaching to the motor/column.306-205 wont look much different, you can use a shortened 306 lower column on a 205! got a 2.4 turn zx rack on my 205, straight on with a 205 column, no pas yet, feels fine with a bit more camber with the 309 arms, just michelin road tyres. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 5th Aug 2016 at 13:46
Post #968
Fingers Crossed |
Posted 5th Aug 2016 at 15:12
blandy
Post #969
welshpug! wrote: same as any other conversion, they need the lower uj welding to the corsa output shaft and suitable brackets attaching to the motor/column. 306-205 wont look much different, you can use a shortened 306 lower column on a 205! got a 2.4 turn zx rack on my 205, straight on with a 205 column, no pas yet, feels fine with a bit more camber with the 309 arms, just michelin road tyres. Thanks thats what i thought. mine is heavy, really heavy running -2deg camber and a 3j diff, again its ok when at speed but on tight turns you can really feel it. Kinda in the same position as Damien if it doesnt work or isnt right itll come off but i have no option bar elec with the sump and rack i have |
Posted 5th Aug 2016 at 16:33
Cjwatson27
Post #970
Wouldn't it work out cheaper and a lot lighter to just get bigger arms ? ________________________________________ Old pugs don't die they just get faster |
Posted 5th Aug 2016 at 19:45
scotzman
Seasoned Pro Location: Dundee Registered: 24 Jun 2011 Posts: 1,408 Status: Offline |
Post #971
Just fit one of these ________________________________________ '90 1.6 205 GTi, '98 306 GTi-6 |
Posted 5th Aug 2016 at 19:52
Post #972
If it would sort it ...I'd fit a Wheel that big Blimey my arms are big enough now without weights or steroids It's after time you feel it Chris ...no PAS is great to drive as you feel the road through the steering wheel amazing Your Like me Mike ...we arnt weak skinny Blokes ...I'm running 2.5 Camber with a 2.4 rack & 3j with race preloads & 205 DZO3gs which are like slicks but road legal ....total bas**rd at slow speed & almost unusable on the road with no PAS ...it beat the hell out of me at Prescott ... My Mechanic m8 Martin can't drive it as it is now ...so I've got to do something ASAP as he helps me loads |
Posted 5th Aug 2016 at 20:17
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Post #973
narrower tyres with lots of air |
Posted 5th Aug 2016 at 20:05
Post #974
cully wrote: narrower tyres with lots of air Dam ....why did I think of that |
Posted 6th Aug 2016 at 06:13
Seasoned Pro Location: Winchester Registered: 21 Nov 2003 Posts: 13,752 Status: Offline |
Post #975
Just man the f**k up grow a pair and use the muscles in your arms - bunch of pussies !!!!!! Hahahahahahahahahahahahaha |
Posted 6th Aug 2016 at 07:05
