Author Subject: Rear Brake Pad How to
Welly Forum Admin
First Things First
Park the car in a suitable place, away from children and pets.
Put the car into Reverse, and chock the front wheels with bricks,
Why
Cos you are taking the rear wheels of the ground which are the hand brake wheels
Welly has attached the following image:
Vrs power!!
Posted 10th Dec 2004 at 15:55
Welly Forum Admin
Loosen off all Wheel nuts whilst car is on the ground..
Vrs power!!
Posted 10th Dec 2004 at 15:58
Welly Forum Admin
Make sure you have the vital equipment on handWhistle Whistle
Vrs power!!
Posted 10th Dec 2004 at 15:59
Welly Forum Admin
Jack the car up from the rear jack point, If possible get a axle stand under as well.
Also remove Jack handle, so you dont trip up over it..
Vrs power!!
Posted 10th Dec 2004 at 16:02
Welly Forum Admin
Undo all wheel bolts,
Take off rear wheel
Release the handbrake gentlyUnsure
And this is what you will look at
Vrs power!!
Posted 10th Dec 2004 at 16:03
Welly Forum Admin
This is what the back of the rear assemble looks like
(Note = These pads are almost new, yes they are that thin to start with)
Vrs power!!
Posted 10th Dec 2004 at 16:04
Welly Forum Admin
Remove spring Clips, These can be fiddly, DONT LOSE THEM
Vrs power!!
Posted 10th Dec 2004 at 20:02
Welly Forum Admin
Now you will need to seperate the pads slighty
Use a Ratchet end to prise them apart slighty off the disc.
The pads wont com out yet but makes the next step easierYes
Vrs power!!
Posted 10th Dec 2004 at 16:08
Welly Forum Admin
You will Need to remove this piece first, It stops the pads sliding out.
First remove the spring clip, It just pulls out DONT LOSE THAT EITHER
Vrs power!!
Posted 10th Dec 2004 at 20:03
Welly Forum Admin
Next pull the little angled bar out..
Its a tough litttle fecker if in doubt knock it with a screw driver from the other side
Vrs power!!
Posted 10th Dec 2004 at 16:11
Welly Forum Admin
Now you can remove yer Pads
Vrs power!!
Posted 10th Dec 2004 at 16:12
Welly Forum Admin
Now when putting the new pads in, you will see that one has a notch in the back..
Like this
Its the pad that sits inwards, that notch sits in piston
Vrs power!!
Posted 10th Dec 2004 at 16:14
Welly Forum Admin
This being the Piston..
Notice it has notches cut out as well, Thats where the pad sits
Vrs power!!
Posted 10th Dec 2004 at 16:15
Welly Forum Admin
A bit further out so you can see better
Vrs power!!
Posted 10th Dec 2004 at 16:16
Welly Forum Admin
Now this piston
DOES NOT PUSH IN, IT TWISTS
Get a screwdriver across the notches and twist the piston back into place, it might not look like its moving but it will...
Offer the pads up a few times to see how your doing,
They will need to be twisted Clockwise.
Vrs power!!
Posted 10th Dec 2004 at 16:18
Welly Forum Admin
This is how the pad should finish up
Vrs power!!
Posted 10th Dec 2004 at 16:19
Welly Forum Admin
Put the Angled Bar and clip back in
Next are these clips..
There is an easy way to do it..
Follow carefully
Offer the clip up into place,
Vrs power!!
Posted 11th Dec 2004 at 17:30
Welly Forum Admin
Now push the bottom peice just under my finger,
Under the little ledge, it will go might just need a bit of force
Vrs power!!
Posted 10th Dec 2004 at 16:21
Welly Forum Admin
It may need a bit off persusion
Vrs power!!
Posted 10th Dec 2004 at 16:24
Welly Forum Admin
Now put it all back together again.
Big grin Big grin
Pull the handbrake up and down a few times and it should re-adjust it self..
Vrs power!!
Posted 10th Dec 2004 at 16:25
This thread has been locked
