Author Subject: blower only working on position4
rikky 🦔
heater blower on a rallye - only working on position4. am fairly sure it worked fine before hand. felt quite stiff messing with the knobs earlier when trying to clear the vents out of with dust, then notice nothing on any setting except full (position4)
read someone said something about cable/flap etc, is this directly behind the heater control panel? or is it something to do with the resistor? it works fine and as you would expect on position4, and also off/quiet on the low positions.
Posted 1st Apr 2021 at 14:49
if it works on 4 then I'd look at the resistor as they run full current in position 4, and through the resistor for 1-3
Posted 1st Apr 2021 at 21:06
rikky 🦔
someone else on here said they had the same thing and it was a cable linked to the flap causing resistor to go bats**t Unsure
ill take a peek tomorrow
ps caliper i binned thread, there was a piece of paint stopping it dropping in
Posted 1st Apr 2021 at 21:28
rikky 🦔
resistor - is that underneath the heater in the foot like the 205 is? eg easy to access? Cheers
Posted 2nd Apr 2021 at 21:00
marksorrento205
It was the resistor on mine when this happened. Under the lower windscreen panel on the LH side. Take off the wiper arm, plastic trim, the rubber boot thing, pull the plastic mesh cap off and you will see it.
Posted 2nd Apr 2021 at 22:46
rikky 🦔
thanks Markus you long haired god
I’ve ordered an overpriced one off Amazon which I’ll get today hopefully and report back, as I know everyone is on the edge of their seat waiting for the outcome
Posted 3rd Apr 2021 at 07:35
rikky 🦔
new resistor thingy under the scuttle panel fixed the problem. cheers
it twists 45° and pulls out to remove for anyone wondering how you get it out
Posted 4th Apr 2021 at 15:29
marksorrento205
Thumbs up result
Posted 5th Apr 2021 at 19:26
russbez
pretty sure mines like this
rikky - where does one purchase new resistor thingy / part code?
My Rallye project thread
Posted 3rd May 2021 at 20:32
rikky 🦔
I just looked on Amazon cos I have Amazon Prime and there was one for £13 or so - Sunday delivery, so just did that. Part no 6450P7 - look on Amazon or eBay if you can wait a day or two for delivery.
Posted 3rd May 2021 at 20:50
russbez
ty man
no rush cars in bits
Posted 3rd May 2021 at 21:00
Robbo1830
Er, is this different on phase 3, followed the above and not seeing what I should…
Just an opening looking down on the fan and the flaps…
Posted 13th Apr 2023 at 15:14
davidmartin
Yep, aircon models are different, the part number 6441A1 should be the one you need, it's on top of the blower motor, ( passenger side footwell the fan you mention) check it is though as they are not cheap and I'm going on doing my phase 1 with air-con.
pet hate, the cat
Posted 14th Apr 2023 at 15:54
Robbo1830
Thanks, thought it may be different somehow.
I can’t see how to get to it though tbh, I’ve had the airbag out but still can’t see how to get to it?
Posted 15th Apr 2023 at 14:05
davidmartin
you need to get on your back by the passenger seat with a torch and underneath the dash/glovebox in the passenger footwell there's a cover take it off you can't miss it then
pet hate, the cat
Posted 15th Apr 2023 at 18:46
pug_306
Undo the torx screws holding the motor in, drop the motor out and you will see the Resistor
1992 205 GTi6
205 Turbo 340bhp
Posted 17th Apr 2023 at 10:06
