Author Subject: Wheel wobble hell!
Ryangt
Looking for some advice please!
I have a steering wheel wobble at 70mph to 100 and a juddering through the pedal on light braking.
I have changed;
front pads& discs with Brembo.
new pins on caliper / pistons moving
new lower arms and bushes
had the wheels balanced twice on a hub attachment type machine.
yet I'm still having this issue?
I'm based in Hampshire.
Old cars
BMW M6 V10
BMW M3 E46
MR2 turbo rev 3
200sx turbo
Fiat coupe 20v turbo
TVR Chimaera 4.0
Posted 7th Sep 2020 at 13:54
Joep
Wheel bearing maybe?
But as it is between 70 and 100 I think it might still be a balancing issue.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Plus various other Peugeots
Posted 7th Sep 2020 at 15:06
A faulty driveshaft can cause this.
Posted 7th Sep 2020 at 19:17
Ryangt
Cheers guys, is there anyway to check the driveshaft? It did make me feel like the balancing.was correct as the guy doing it had a ralley, wheels also look like they aren't buckled.
Old cars
BMW M6 V10
BMW M3 E46
MR2 turbo rev 3
200sx turbo
TVR Chimaera 4.0
Posted 7th Sep 2020 at 22:33
Ryangt
swapped the front wheels for the back and now it has gone!
The wheels said on the balancing machine they had been balanced guessing a slight buckle.
All fix
Old cars
BMW M6 V10
BMW M3 E46
MR2 turbo rev 3
200sx turbo
TVR Chimaera 4.0
Posted 15th Sep 2020 at 08:22
Balancing then Thumbs up
Posted 16th Sep 2020 at 10:52
pugfrank
I have changed;
I have been chasing the exact same issue on my 6 for the last couple of weeks! its driving me insane!
I have just read that you swapped your wheels from front to back and it sorted the problem. Guess what ill be doing tonight if I get home before the day light goes.
Posted 14th Oct 2020 at 12:29
pugfrank
Damn, changed the wheels around and it made no difference!
Posted 15th Oct 2020 at 12:56
Joep
When does it exactly occur?
When you lift? When you corner? Under braking? At certain speeds?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 15th Oct 2020 at 14:28
pugfrank
So I changed the discs and pads on front, cleaned and greased sliders, pistons moving freely it appears and it has cured the wobble at speed Smile along with the peddle and wheel wobble when braking in a straight line between 70-45mph Smile
One step forward and two back!
Now the car is pulling to the right under medium to heavy braking from 70mph down to a stop! ffs!
What can it be now!??
Posted 20th Oct 2020 at 20:45
Joep
Failing ABS maybe? I assume you cleaned the brakes on both sides?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 20th Oct 2020 at 20:51
pugfrank
Yes I checked callipers when changing pads, appeared to move freely to me.
It has since been to the garage. Not my usual as I needed to fit it in nearer to where I work.
They reported that the car appears to be puling to right hand side! No **** sherlock!
They suggested bleeding brakes through in case air in system, they have done this no change.
They have then proceeded to tell me they don't know what is wrong and handed the keys back to me! What a garage!!
Can you test the ABS unit in anyway! sounds expensive!
Posted 22nd Oct 2020 at 14:13
Joep
Okay. That is a garage to avoid for future repairs indeed.
When I changed the brakes on my most recent GTi, everything looked okay. Everything was smooth and clean. Could push back the caliper without much issue... not even one week later I had vibrations (mainly under braking) but also when going around corners.
Did you do a refurb of the brakes? Cleaning slider pins and adding new grease to the slider pins? I had one that was seized due to rust accumulating around the slider pin. That was causing all the issues.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 22nd Oct 2020 at 14:45
pugfrank
Yes a garage to avoid from now on!
I removed the slider pins cleaned up applied new grease and they all moved freely.
The calipers were new around 2500 miles ago along with new flexible brake hoses. Fitted by previous owners garage.
What can go wrong up stream of the calipers? Flexible brake lines, brake servo, abs unit?
Could any of these cause the pistons to not retract properly after stepping on the brakes?
Posted 22nd Oct 2020 at 20:59
Joep
I was just reading older posts: is the suspension still okay?
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 22nd Oct 2020 at 21:37
pugfrank
I believe so, it has had new wishbones, ball joints and drop links last month. Shocks and springs are 6months old.
Posted 22nd Oct 2020 at 21:50
Joep
Might be worthwhile to check if all the bolts are still tightened. I changed the wishbones before summer and I had to tighten the bolts again mid summer.
Also, if the bolt in the top-mount is not tightened, this can cause strange effects... I did not tighten one, and I had vibrations and knocking throughout the car (enhanced experience because of solid mounts and no insulation). One fourth of a turn was enough to have it resolved.
My car park:
'96 Sigma Blue XSi6
'98 Diablo Red GTi6
'99 Onyx Black S16
All RFS powered!
Posted 23rd Oct 2020 at 07:17
pugfrank
Yes good shout the shock top nut is probably the only nut I haven't gone over twice now and checked, worth a double check.
Posted 23rd Oct 2020 at 07:30
Gearbox mount caused this on my car one time.
Posted 23rd Oct 2020 at 17:06
