Author Subject: Hybrid Xu7jp4rs
Tork Steher
Hi
I've been slowly building a 1.8 Xsi track car, it currently has the alloy block with a gti6 head and cams, gti exhaust manifold, stock intake manifold cut for gsxr1000 itb's. Running with a microsquirt.
The car is pretty quick hasn't been dynoed yet but it can keep up with a clio 172.
Still i feel like especially after the itb, it now needs more cam.
I know the gti6 has piston clearance issues with taller cams, but how about the 1.8 with stock pistons? a bit more room maybe?
Also has anyone used catcams 4903156 282ยบ with 10mm lift ?
Good insight welcomed regarding cam choices
thanks
An idle isn't lumpy till bits of engine come out the exhaust!
Posted 10th Mar 2020 at 13:13
less room if anything ss ghe exhaust valves are larger, I hink the gti6 springs will go to 10.8mm peak lift from memory
there is a thread on here about cams, max liff @ tdc yiu want to google.
Posted 10th Mar 2020 at 16:27
jeffers Forum Owner
http://www.306gti6.com/forum/showthread.php?id=104146
Team Running Engine again!
Team Negative Camber!
Posted 13th Mar 2020 at 13:26
Tork Steher
Thanks Jeffers I read it.
Guess nothing better than taking head off and test/measure.
the 205 mob should have a bit more info about it since the xu7 16v has the same pistons as the 1.9 mi16 I'm lead to
believe?!?
Posted 13th Mar 2020 at 18:10
no, they are quite different, xu7 has quite a long rod at 150mm, small dish in the piston, I don't recall the crown height but could easily work it out.
xu9j4 has a 143mm rod and 37.1 crown height and quite large valve reliefs.
Posted 14th Mar 2020 at 08:36
Tork Steher
According to Sandy from the 205 forum in case someone like me needs details about this very common engine
XU7JP4:
Block height from crank centre line 224.5mm
Stroke 81.4mm
Bore 83.0mm
Rod length centre to centre 150.5mm
Big end journal diameter 45mm
Small end diameter 22mm (Interference fit)
Piston crown height from pin centre 33.3mm
Pistons rise flush with deck at TDC
Piston crown total volume (dish and cutouts) ~ 2.0cc
Gasket volume (1.4mm x 84mm dia) ~ 7.8cc
Chamber volume standard ~ 37.2cc
Chamber volume with 0.25mm skim (maximum practical) ~ 36.0cc
Standard CR 10.4:1
Skimmed CR 10.6:1
Inlet valve cutout 2.5mm max lift at TDC (allowing 1.5mm clearance)
Exhaust valve cutout 2.0mm max lift at TDC (allowing 1.5mm clearance)
Inlet valve diameter 34.6mm
Exhaust valve diameter 29.6mm
Posted 16th Mar 2020 at 00:01
Greenlight Insurance
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2020 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
