Author | Subject: Transponder location ph2 ph3 - in case somebody needs |
![]() Newbie ![]() Location: Zagreb Registered: 18 Oct 2017 Posts: 2 Status: Offline |
Yesterday I was changing ecu, transponder and key in my 306 '99 1.8 16v, since it is hard to find it just looking around here are some photos of location, in case sombody need this in the future and don't want to make a mess like me ![]() ![]() ![]() |
![]() Seasoned Pro ![]() Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,605 Status: Offline |
Is it the same for RHD?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
![]() Formerly gpm ![]() Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,843 Status: Offline |
Transponder is a black plastic ring that sits around the ignition barrel I think.Trying to find a pic. ________________________________________ Cherry Red Rallye ....On going OEM spec restoPh2 Xsara VTS |
![]() Seasoned Pro ![]() Location: Great Hockham Registered: 28 May 2013 Posts: 1,562 Status: Online |
Ben_W wrote: Transponder is a black plastic ring that sits around the ignition barrel I think. Trying to find a pic. I call that the antenna. That's not a coded part. ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 |
baho wrote: no sorry... it is a black box, larger than cigarette box and it is under the emergency light switch, fog lights switch, positioned like HU but smaller and at the bottom of the central part, guess rhd drive on the same place Yup same place. Please 2 is clipped in and phase 2.5 and phase 3 is held in by 3x torx screws. Easy to remove ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 |
![]() Regular ![]() Location: Cologne Registered: 09 Nov 2015 Posts: 357 Status: Offline |
Yeah that black plastic ring next to the ignition barrel is the antenna. It is a coil that powers the transponder (chip with unique ID in a little black plastic body inside the key housing) and picks up the data from it. The black control unit next to the ashtray is the so called CPH (compartment protection something in french a.f.a.i.r.). The CPH receives the data from the coil and decides whether to unlock the ECU or not (immo). |
![]() Capt Pedantic ![]() Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,593 Status: Offline |
yep, the antenna is just that, an aerial to pick up the chip, its a generic part so you don't need to swap it, nor do you need to change the ignition switch, all you need is the chip from the key if its an IR setup, the later RF you need the whole fob.of yeah and its not the BSI as the 306oc lot love to call it ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2019 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
