Author Subject: Chassis repair
Laytj
Hi all
My phase 1 GTI6 requires some fabrication/repair to the o/s front chassis outrigger on the drivers footwell. Anyone else done this? Is it worth cutting a section out of a donor vehicle? Thanks all
L james
Posted 9th Oct 2019 at 06:15
jeffers Forum Owner
Get yourself a good donor part if you can, looks much nicer imo!
Team Running Engine again!
Team Negative Camber!
Posted 9th Oct 2019 at 07:16
Laytj
Thanks for your reply, I have a 306 Estate with mint outriggers I can cut out so maybe i'll do that, can you get away with just dropping the subframe a couple of inches to get to it properly?
L james
Posted 9th Oct 2019 at 07:33
S8-Tom
Have a look at Ben's thread, he's been undertaking this repair recently.
Posted 9th Oct 2019 at 09:15
Ben_W
Formerly gpm
Thanks Tom
Yes, I was lucky enough to find a NOS panel, as well as a very very good s/h panel, which are the ones going onto the car.
I do have some potential parts. Last two Xsaras I've broken, I've cut the stiffener panels (outriggers) out. A pair of these are promised to Alistair (I'm on it fella....sorry, been silly busy working on a lease renewal proposal at work) and one other is supposed to be going to someone who's gone radio silent...
May have one, if not a pair going.
My recommendations? Don't go the route I have unless you absolutely need to. They are almost impossible to remove without a rollover jig, and having to remove all the subframe etc, mainly due to the sheer amount of spot welds per panel (maybe 40+). Usually, it's not the subframe mounts section that gets damaged, moreso the outer section. If possible, I'd look to just replace the outer section. Removing the whole thing then requires doing it one at a time so youve always got a factory aligned mount to set up off to keep it all square....
China Blue GTi6 .... Daily driver
Silver Ph2 Xsara VTS
Posted 9th Oct 2019 at 21:28
Laytj
Thanks for that Ben, Mine has gone slightly under the subframe mount section, So would i get away with just lowering the subframe slightly to repair or does it need to be dropped fully? Thanks
L james
Posted 10th Oct 2019 at 09:53
Ben_W
Formerly gpm
You'll need to drop the subframe fully I'd image. Access is a pig
Posted 10th Oct 2019 at 10:25
Laytj
Ok Thanks mate
L james
Posted 10th Oct 2019 at 11:10
Even with the subframe completely off and the car sat on high custom made axle stands it's a pig of a job to do, as Ben said. Not something i ever want to do again! Laugh
Posted 10th Oct 2019 at 16:31
alcon
Also, as Ben said, a roll over jig is the only way I'd consider cutting the arse out my car but that means you'd need to pretty much strip it to a shell. You'll have to have the interior out for cutting and welding and for proper access, engine out as well. Yeah, its a big job.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 10th Oct 2019 at 19:08
Ben_W
Formerly gpm
Some info you might need Mr James.
The panels, especially around the subframe mounts, are made of several parts, 5 to be exact (outer skin, inner panel, leg, two mount bolt captive nuts). They are layered around the subframe bolt captive nuts.
It could make replacement of that particular area interesting. If it's bad enough to warrant replacement, you may be better off doing the whole section, but that's going to require a lot of steip down work to facilitate.
Posted 11th Oct 2019 at 19:42
Laytj
Thanks all for the information, mine isn’t too bad, I can’t see how I upload photos from my phone to the thread? Any tips lol?
Thanks again
L james
Posted 11th Oct 2019 at 20:12
Ben_W
Formerly gpm
I use http://www.imgbb.com
Posted 11th Oct 2019 at 20:55
What's the part numbers?
Posted 14th Oct 2019 at 11:08
2000 Peugeot 306 GTi-6
  • 2000cc
  • Grey
  • 74,000 miles
£1,200
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2020 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
