S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired
Author | Subject: Door Check Strap |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I'm dismantlting my damaged driver's door for the lock barrel, etc and want to remove the check strap but can't get it through the hole. I'm cutting up the door to get the lock barrel out so can do the same for the check strap, but how can I fit to a good door?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 28th Jul 2019 at 09:04
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,593 Status: Offline |
rudolf wrote: I'm dismantlting my damaged driver's door for the lock barrel, etc and want to remove the check strap but can't get it through the hole. I'm cutting up the door to get the lock barrel out so can do the same for the check strap, but how can I fit to a good door? Why are you cutting up the door ? The barrel is just held in place by a metal clip. The check strap is 4 x 10mm and knock out the roll pin. The lock and check strap are removed from inside the door ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Posted 28th Jul 2019 at 09:38
My door was badly crushed by the artic so no space to get the contents out!I'll cut out the check strap then knock out the roll bin on a bench - Can they be re-used? ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 28th Jul 2019 at 09:53
