Author Subject: Power Steering Pipe
DuncBurr
Hello
I am after a replacement power steering pipe, it is the metal pipe that coils round and attaches the sub frame via the rubber mount, mine has corroded and poured power steering oil all over the exhaust. Anyone know where i can get one from, really struggling to find anywhere with one.
Thanks
Duncan
Posted 15th Apr 2019 at 17:28
alcon
DuncBurr wrote:
Hello
Thanks
Duncan
Is that the high pressure one that goes from the pump straight to the rack and consists of metal pipe and rubber hose?
Depending on your end connections I may have one for you.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 16th Apr 2019 at 14:28
pug_306
All gti6 will be the same buddy just the sensor may need swapping over if it's a different connection. If alcon doesn't have one I should have one, but won't be able to check till next Tuesday.
1992 205 GTi6
205 Turbo 340bhp
Posted 16th Apr 2019 at 14:40
DuncBurr wrote:
Hello
Thanks
Duncan
I had the same issue a few weeks ago, ended up having a new one made by pirtek
Posted 16th Apr 2019 at 15:23
DuncBurr
alcon wrote:
DuncBurr wrote:
Hello
Thanks
Duncan
Yes it is, I believe, I can send you a picture if you want to be certain.
Posted 16th Apr 2019 at 15:28
alcon
The reason I was asking about the end connections is because the new rack and pipework I bought was from a Xsara VTS and I noticed the pipe ends are different to the ones I removed from the Rallye. Ryan has confirmed all GTi-6's are the same but I'm wondering if there's a difference between the 6 and the rallye.
There part number of the pipe for my 6 is 4014 33 but for the rallye it's 4020 KQ.
1999 Rallye (black)
Posted 16th Apr 2019 at 15:35
DuncBurr
The pipe is currently still fitted to the car so can't see it fully for a P/N or 1 of the connectors. 1 end is just a rubber pipe over the metal pipe held on with an O clip.
Posted 16th Apr 2019 at 15:42
alcon
The difference is where it connects to the rack. The VTS pipe is held in place with a metal plate but the 306 ones have a threaded union similar to a brake pipe. When I'm back at the garage I've have a look at the ones I've got and let you know or send you pics.
1999 Rallye (black)
Posted 16th Apr 2019 at 15:46
DuncBurr
Many thanks I appreciate your help
Posted 16th Apr 2019 at 15:49
DuncBurr
Did you get chance to see if you have the same pipe?
Posted 23rd Apr 2019 at 09:30
alcon
This is the pipe I have. Ignore the masking tape on the rubber hose, I was blasting and painting the ends but never finished the middle section.
1999 Rallye (black)
Posted 24th Apr 2019 at 10:06
alcon
1999 Rallye (black)
Posted 24th Apr 2019 at 10:15
DuncBurr
Yeah it is a different connection where it goes into the rack, it needs to have the threaded Union connection for the 306. Thanks for looking anyway.
Posted 24th Apr 2019 at 12:50
pug_306
That's not a full pipe it's been cut hasn't it ?
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Apr 2019 at 14:11
alcon
No, it's not cut but there's another metal pipe that connects to the end. It was off for cleaning and painting.
1999 Rallye (black)
Posted 24th Apr 2019 at 14:17
pug_306
I think that's been cut and joined in the past as I didn't think they came off. If it was from your gti6 it will be threaded and will be fine for the guy after one :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Apr 2019 at 14:24
alcon
This is the full pipe before I started cleaning it.
1999 Rallye (black)
Posted 24th Apr 2019 at 15:09
pug_306
Yep that's the correct one. All gti6 are threaded, looks to of had that part repaired in the past as usually they don't come apart there ( well not the ones I've seen )
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Apr 2019 at 15:30
alcon
do the xsara vts pipes come apart at this location??
1999 Rallye (black)
Posted 24th Apr 2019 at 15:36
pug_306
Not that I know of ??
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Apr 2019 at 16:15
alcon
Mine definitely unscrewed and I'm pretty sure it's all original. I just can't remember if this is the pipe of the Rallye or the one off the Xsara rack I bought!!
1999 Rallye (black)
Posted 24th Apr 2019 at 20:30
pug_306
That looks threaded at the rack end so it's a 306 pipe. The vts p2 are push fit with a bolt in the middle holding both pipes. I've not seen a vts or 306 one come apart like that before.
1992 205 GTi6
205 Turbo 340bhp
Posted 24th Apr 2019 at 21:12
DuncBurr
Thats the one, its the metal part that's corroded just after the rubber pipe where it bends round in a U shape.
Posted 25th Apr 2019 at 12:10
yeah all the 306/partner ones have the joint for the last section that I recall, as did my ZX.
Posted 25th Apr 2019 at 13:43
pug_306
That's strange I've got 4 that are 1 complete unit LOL 2x VTS and 2x GTi6
Maybe they are different between phases but I've never noticed any that come apart there
1992 205 GTi6
205 Turbo 340bhp
Posted 25th Apr 2019 at 13:54
