Author | Subject: Engine |
prparke
Newbie Location: Holywood Registered: 30 Apr 2012 Posts: 47 Status: Offline |
GTI 6 engine not starting, its turning over that's it. replaced fuel pump relay yesterday and no joy. |
Posted 21st Mar 2019 at 08:18
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,593 Status: Offline |
Are you getting spark and fuel ?________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Posted 21st Mar 2019 at 08:26
Joep
Regular Location: Urmond (The Netherlands) Registered: 19 Sep 2013 Posts: 463 Status: Offline |
Is it the original engine? Found out recently that the ECU has to match the keys when it is a phase 2/3.________________________________________ My car park:'96 Sigma Blue XSi6 '98 Diablo Red GTi6 '99 Onyx Black S16 All RFS powered! Plus various other Peugeots |
Posted 21st Mar 2019 at 09:01
prparke
quote: [quote="Joep"]Is it the original engine? Found out recently that the ECU has to match the keys when it is a phase 2/3. Engine, ecu, keys etc is from same car |
Posted 21st Mar 2019 at 14:19
pug_306
But is it the original engine or have you swapped it from another car? If so did you swap the transponder also ? If so check if you have spark and fuel ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Posted 21st Mar 2019 at 14:22
prparke
quote: [quote="pug_306"]But is it the original engine or have you swapped it from another car? If so did you swap the transponder also ? If so check if you have spark and fuel 3 doorGTI 6 car everything from it was swapped over |
Posted 21st Mar 2019 at 15:41
pug_306
Including the transponder control unit in the dash ?If so do you have spark and fuel ? ________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Posted 21st Mar 2019 at 15:46
prparke
quote: [quote="pug_306"]Including the transponder control unit in the dash ? If so do you have spark and fuel ? Transponder, dash, speedometer etc. |
Posted 21st Mar 2019 at 17:41
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 389 Status: Offline |
Does the engine management light turn on with ignition? If so, you need to verify if you get spark and fuel as pug_306 already said. |
Posted 22nd Mar 2019 at 00:33
fletch
Track Head Location: The nearest Shell garage Registered: 12 Jun 2004 Posts: 12,273 Status: Offline |
Does the fuel pump prime?Fuel? Spark? Dodgy crank sensor could be at fault |
Posted 22nd Mar 2019 at 14:01
Cjwatson27
Red cut out switch ________________________________________ Old pugs don't die they just get faster |
Posted 22nd Mar 2019 at 14:18
