Author Subject: Super high boost dimma parts
pugheaven
Now I have the new engine and 4wd system for the dimma I will be selling lots of parts which are listed below.
Still can't decide if I should use my genuine steel bodied dimma or sell it and use a fibre glass kit on a spare shell i have.
The dimma will still be on the road for a bit so if a buyer for the engine wants to see it running and go out for a spin this is possible.
So here is the list and prices
Super high boost engine and charger setup
I can list every part and build spec but most of you know what it is. Will be pretty much plug and play minus the fuel system, intercooler, rad and exhaust manifold £6000
Yes I sold the last one for a bit less but that was for a quick sale, and came with less parts for example silicon dress up kit (water and oil), custom ecu holder, painted engine, bt adaptor to use the dta app for all engine info and gauges
Early gti6 gearbox and diff £500
Satch shift £300
Vibra technics top engine, gearbox mount and a Phillip m solid bottom mount £200
Front wide track... shafts, wishbones, track rod extensions and McPherson top mount adaptors £800
Custom ultra low bc front coilovers and rear dampers plus additional different lb springs £800
Custom wide track rear beam... 80mm wide track built and machined by bridgecraft with -3 degrees of camber.
22.5mm torsion bars
30mm arb
Solid rear mounts
Wp pro big brake kit 310mm
The beam was built 5k mikes ago using all Peugeot parts (every nut bolt and washer) including new trailing arm shafts and hub bearings
£800
Ceramic coated exhaust manifold £300
Ap racing 315mm 4 pot brake kit £850
Custom roll cage, goes to the beam mounts on the boot floor, has an x, harness bars and twin dog leg door bars £600
The current 18x8 revolution millennium wheels fitted to my car with front ns2r tyres and pilot sport 3 on the rear £550
So are set of brand new 18x8 revolution millennium wheels £550
Custom 3" exhaust from manifold back made by torque techniques £600
Front -2 degrees negative camber hubs done by bridgecraft, powder coated and new hub bearings 5k miles ago £250
Custom bulk head hugging strut brace £100
Phillip m brand new never fitted twin tube lower brace £80
2.4 xsara vts quick rack £300
Bridge craft custom adjustable top mounts (raise up into the engine bay) £300
Probably forgot loads of bits
Posted 14th Mar 2019 at 12:10
blandy
Have you got any pics of the cage?
Posted 14th Mar 2019 at 06:56
pug_306
Pictures of exhaust please, also what size is the tailpipe.
Regarding the gearbox what diff is in it ?
1992 205 GTi6
Posted 14th Mar 2019 at 07:31
pugheaven
Best to msg me on Facebook for pics.
The exhaust is centre exit and a 3" tip.
The diff is quaiffe
Posted 14th Mar 2019 at 09:05
pugheaven
Not that iv had much sold from this site but most of the stuff is sold except from:
Roll cage
Front wide track
Exhaust manifold
Wheels
Mounts
As most of you are aware I'm "Oliver Church" on Facebook if you want anything
Posted 9th Apr 2019 at 18:37
Greenlight Insurance
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2019 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
