Author Subject: Led flashing
inzomatic
The red alarm led seems to be flashing quite fast when I lock the car is this normal? Siren has not worked since I've owned it but the lights flash when you push the button when locked in the car
Innes drummond
Posted 18th Dec 2018 at 20:10
mocinim
Ph3 ?? Mine used to also was always fine at that
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 18th Dec 2018 at 20:20
cully
mine only fast flash's after the alarm has been set off
Posted 15th Feb 2019 at 08:36
I can set the alarm off on mine by walking into the kitchen and looking out the window at it. The LED flashes fast then it resets itself the next time you use it after it alerting you to the breach of just being French. Given alarms on these cars don't work anymore due to the sirens failing via batteries and water ingress it's nothing to massively worry about, anything flashing internally is a mild deterrent in my view plus if you leave nothing obvious to steal then the alarm isn't really going to be tested, famous last words. I've a Tesco Bag for Life currently on the back seat I need to return as it hasn't lasted for life and that's still there.
Posted 17th Feb 2019 at 00:19
cully
you realise these alarm box's are fitted to the 206 as well! they dont need programming just need to find one with same part number.
i did this and remounted it on the bulkhead away from the water now have a working alarm!
Posted 17th Feb 2019 at 08:33
