Author Subject: Heater Controls
My auto fan control doesn't work properly and don't always get heat from the heater even though it is fully bled.
Does the heater panel control both of these?
S Reg Diablo Standard Spec
R Reg Nile Standard Spec
Posted 30th Oct 2018 at 22:00
miki4
If your interior blower fan is cutting out randomly, check the corresponding relay. The control unit gets power through it as well. If the relay fails a chain reaction evolves. A worn relay heats up way too much when passing a high current (which is the case with a running blower motor) due to high contact resistance. The heat will melt its socket and corrode the contact pins as well as the crimping. Happened with mine a few weeks ago. Had to replace the whole socket with one from a breaker.
If your relay socket looks okay still you can open up the relay and refresh the contact surface or just replace it. For testing you could just bridge the two high current pins in the socket.
EDIT: Yes, the control unit also controls the flap which directs the air through the heater matrix.
Posted 31st Oct 2018 at 17:34
The fan works fine when selecting a speed manually, just goes from off to full on its own on AUTO sometimes.
Looks like a new control panel then look at the old one once out.
Posted 31st Oct 2018 at 23:07
1999 Subaru Impreza RB5 Uk 2000 turbo Richard Burns
  • 2000cc
  • Grey
  • 127 miles
£2,850
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2019 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
