'01 Astor Grey GTi6'99 Cherry Rallye
Author | Subject: Clutch pedal on the floor |
asim_pug306
Senior User Location: Bradford Registered: 26 Aug 2009 Posts: 933 Status: Offline |
Went to move the car last night, put the clutch down and it just got stuck on the floor. It'll come up by hand but even the slightest touch on the pedal and it springs straight back down. A quick glance and the cable seems to be in tact________________________________________ '01 Astor Grey GTi6'99 Cherry Rallye |
Posted 4th Jul 2018 at 10:07
marksorrento205
Seasoned Pro Location: Airborne in the lanes Registered: 26 Aug 2008 Posts: 2,221 Status: Offline |
Clutch cable snapped or become uncooked at the pedal? Does the clutch arm move on the gearbox when the pedal is moved?________________________________________ How to do a clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 4th Jul 2018 at 16:54
stan_306gti6
Forum Admin Location: Kent Registered: 18 Jan 2004 Posts: 21,768 Status: Offline |
Yep, sounds like it's snapped. As Mark says, check the arm moves on the gearbox when using the pedal. I reckon it won't.Clutch cable isn't too bad a job, can be a bit awkward if you've got air-con. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
Posted 4th Jul 2018 at 20:50
asim_pug306
New clutch cable fitted but still no joy ________________________________________ '01 Astor Grey GTi6'99 Cherry Rallye |
Posted 10th Jul 2018 at 08:47
Seasoned Pro Location: DoncastAAAAARGH Registered: 13 Jan 2008 Posts: 4,637 Status: Offline |
Is the clutch arm pin still in place?________________________________________ Goldie the track car. |
Posted 10th Jul 2018 at 12:06
fatlapit
Ledal mechanism working??________________________________________ |
Posted 10th Jul 2018 at 20:33
asim_pug306
Ignore my above post, I was wrongly informed at the time! A new clutch cable did actually sort it. However last night I took the car out for it's first proper drive since having it back. After around half an hour, it became really difficult to get the thing into gear and you can feel it struggling slightly at junctions with the clutch down. It actually feels like there's less travel in the pedal too. I've just gone back to the garage this morning and they've said that the cable should self adjust so that can't be at fault? They think it's the pressure plate but it's a bit strange that my car never did this before the cable snapping ________________________________________ '01 Astor Grey GTi6'99 Cherry Rallye |
Posted 19th Jul 2018 at 10:38
gnrlee
Forum Admin Location: Leeds Registered: 20 Aug 2005 Posts: 8,878 Status: Offline |
Give it a couple of days they are self adjusting though! ________________________________________ Proud Member of the ASTOR Owners Club |
Posted 19th Jul 2018 at 12:44
barrym
Senior User Location: Westcliff-on-sea Registered: 26 Jun 2014 Posts: 502 Status: Offline |
quote: [quote="asim_pug306"]Ignore my above post, I was wrongly informed at the time! A new clutch cable did actually sort it. However last night I took the car out for it's first proper drive since having it back. After around half an hour, it became really difficult to get the thing into gear and you can feel it struggling slightly at junctions with the clutch down. It actually feels like there's less travel in the pedal too. I've just gone back to the garage this morning and they've said that the cable should self adjust so that can't be at fault? They think it's the pressure plate but it's a bit strange that my car never did this before the cable snapping I had this exact same issue with a new, but faulty, cable. It needs replacing again I reckon ________________________________________ China D Turbo HDi daily chargerBlack Rallye occassional toy |
Posted 19th Jul 2018 at 18:51
asim_pug306
quote: [quote="barrym"]I had this exact same issue with a new, but faulty, cable. It needs replacing again I reckon Was yours a genuine dealer part or pattern? ________________________________________ '01 Astor Grey GTi6'99 Cherry Rallye |
Posted 20th Jul 2018 at 14:34
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 389 Status: Offline |
My ATE clutch cable which seems to be the only one available for a LHD GTI6 with a well-known brand on it also has way too much play on the top of the clutch pedal travel. It's self-adjusting and adjusts itself always to this s**t state. I will be replacing it to a OEM one. |
Posted 20th Jul 2018 at 15:39
barrym
quote: [quote="asim_pug306"] quote: [quote="barrym"]I had this exact same issue with a new, but faulty, cable. It needs replacing again I reckon Was yours a genuine dealer part or pattern? Was a pattern part, but even OEM parts can be faulty. Mine was actually fine almost all the time. It only played up on very hot days after being stuck in traffic. The amount of pedal travel would go down. A couple of quick pushes of the clutch pedal would 'reset'it for a bit but it would gradually get worse. Park the car up and let it cool down and it would be fine again for a while. took it back to the garage that fitted it and they just replaced it under warranty, been fine ever since ________________________________________ China D Turbo HDi daily chargerBlack Rallye occassional toy |
Posted 20th Jul 2018 at 19:43
asim_pug306
Still not solved this. So we went and replaced the clutch cable again for an OEM one from Peugeot this time. Again had exactly the same problem, stiff gear change once up to temperature.My friend reckons this little bush doesn't look in too good shape and could be causing the problem. IMG-20180807-WA0005 by Asim Malik, on Flickr The cable did seem to have some play in it from on top of the gearbox after it was fitted. Question is will I be able to get one of them little things ________________________________________ '01 Astor Grey GTi6'99 Cherry Rallye |
Posted 7th Aug 2018 at 19:57
barrym
The bush is available from Peugeot. Part number 2175 21. £2.59 +VAT________________________________________ China D Turbo HDi daily chargerBlack Rallye occassional toy |
Posted 8th Aug 2018 at 18:38
malo225
Regular Location: Aberdare Registered: 27 Mar 2014 Posts: 124 Status: Offline |
I would replace the bottom one too |
Posted 9th Aug 2018 at 21:30
miki4
Yes, replace both ones. And there is a newer revised design of them available. Get the newer ones! AFAIK they are less prone to wear out from ingress of clutch dust. Unfortunately I cannot access ServiceBox where I am right now but someone should be able to find out the part numbers. |
Posted 10th Aug 2018 at 12:49
