Author Subject: Wire Codes
eddy_gti6
Got a list of wires im trying to find out what they do, havibg an issue at the minute where i turn on the side lights and it powers up the van to the 1st click on the ignition even without the key in.
Anyobe able to help? These wires all come from the small plug off the headlight stalk.
177 * BMF22 * Yellow
177 * BMF21 * Yellow
174 * VV2 * Grey
174 * VV * Grey
178 * 250 * Light Blue
175 * B071 * White
Also when i put lights on one of the green relays clicks. Wires to that relay listed below
Green Relay - thick red, green & yellow, yellow+red, grey
Posted 11th Feb 2018 at 18:28
jorg
174 * VV2 * Grey = Sidelights
174 * VV * Grey = Sidelights
178 * 250 * Light Blue = Horn
can't help with the others i'm afraid
B071 is 12v to column
306 2.1 S16 Tarmac Rally Car
Posted 11th Feb 2018 at 18:32
eddy_gti6
Thanks jorg, need to trace the 2 grey wires to see where they go and find out when they bring on ignition. They also stay on when i turn all lights off but have ignition on so assume someone has wired them straight to a 12v feed or ignition feed
Posted 11th Feb 2018 at 18:44
Does it turn the dash light on then, or just prime the fuel pump?
Posted 11th Feb 2018 at 20:12
cully
pin 1b bmf22 is fused + from engine fuse box fuse MF2
pin 2b bmf21 is fused + from engine fuse box fuse MF2
pin 3b vv/vv2 wire to cabin fuse box F9 (side lights) + F19 (dash lights)
pin 1a 250 wire to horn sounder
pin 3a b170 feed for horn fused at cabin fuse box f17
Posted 11th Feb 2018 at 20:20
cully
has someone installed a diode and or a switch on the wires to the light stalk?
they may have wrongly wired a fog flash mode that I wrote a guide too on OC
Posted 11th Feb 2018 at 20:23
cully
what car is this?
as I dont think the relays should be plugged in
one is
2400 side light day running lights line relay
2401 dipped bean day running light relay
Posted 11th Feb 2018 at 20:35
eddy_gti6
quote:
[quote="adam b"]Does it turn the dash light on then, or just prime the fuel pump?
No key in but turn on side lights and side lights come on, battery light on the dash and powers everything that gets power from 1st click of the key. No fuel pump, thats 2nd click of the key.
Posted 11th Feb 2018 at 20:56
eddy_gti6
quote:
[quote="cully"]what car is this?
one is
Its my berlingo van but running the full 306 rallye engine, box and all looms front to back what i fitted. Everything use to work as normal when i built it but now someone has been messing with it and cant figure out what has been done?
Posted 11th Feb 2018 at 20:57
