Author Subject: Gearbox grinding under load when cornering
demondriverdan
Weird one from the race car today. When turning right at reasonable speed there's a grinding noise from the gearbox through the Satchshift. It feels like another gear is trying to engage, if I push the Satchshift further to the left the noise gets louder and likewise when I pull it toward me the noise gets quieter.
Initially I thought it was just a Satchshift alignment issue but we've messed around with it a lot and couldn't get the noise to stop. It's only under reasonable load, if I slow down the noise goes away or if I turn the steering wheel less it goes away.
Any ideas? I'm pretty stumped!
Rallye Race Car
Posted 3rd Feb 2018 at 19:09
tvrfan007
What’s the history of the box? have you had the satchshift fitted long?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 3rd Feb 2018 at 21:44
mocinim
Sure its not the wheel bearing chap???
Had the same issue a while back could of sworn it was the box
But was indeed the neerside bearing
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 4th Feb 2018 at 00:17
3rd time lucky
Sounds similar to mine when the driveshaft went.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 4th Feb 2018 at 00:57
marksorrento205
I would say shaft or wheel bearing
Posted 4th Feb 2018 at 09:33
demondriverdan
What I don't get with those is why it only is an issue in such limited circumstances? Particularly a wheel bearing, why only on power and why can I feel it through the gear stick. The shaft I can sort of understand but still don't know why I can feel it on the stick
Rallye Race Car
Posted 4th Feb 2018 at 21:06
blandy
Diff?
Posted 4th Feb 2018 at 21:29
quote:
[quote="demondriverdan"]What I don't get with those is why it only is an issue in such limited circumstances? Particularly a wheel bearing, why only on power and why can I feel it through the gear stick. The shaft I can sort of understand but still don't know why I can feel it on the stick
Properly because you have solid engine mounts now Dan ...anything wrong / vibrates straight down anything loose ...EG ...satchell gear rods etc
3rd time lucky
I’m not sure how exactly but my gearstick was shaking like mad when under load. Even the dash was shaking up and down. We thought it must be engine mount completely gone but it turned out to be the drive shaft.
BLACK RALLYE - Sold
Posted 5th Feb 2018 at 00:28
It does sound like a shaft...Yes
Danny when yours was gone in France that time I thought the engine was going to drop out the bottom! Following your car and seeing the tailpipe bouncing violently side to side in the bumper cutout was slightly unnerving! LOL
Posted 5th Feb 2018 at 22:51
3rd time lucky
quote:
[quote="stan_306gti6"]It does sound like a shaft...Yes
Ohh yea I forgot about the exhaust wobble LOL it literally affected the whole car.
BLACK RALLYE - Sold
Posted 5th Feb 2018 at 23:03
demondriverdan
Cheers guys. Dan, which shaft did you need to replace? Might be worth getting both, assuming I can find some at a reasonable price!
Rallye Race Car
Posted 23rd Feb 2018 at 22:08
mocinim
The long shaft most likely , can give gearstick wobble when the inner joint is bolloxed
Posted 24th Feb 2018 at 18:25
or not seated right
mine used to wobble,....
after having it all apart and back together fine now,.. but never had any grinding though :thinking
Posted 24th Feb 2018 at 19:51
3rd time lucky
quote:
[quote="demondriverdan"]Cheers guys. Dan, which shaft did you need to replace? Might be worth getting both, assuming I can find some at a reasonable price!
I’m almost certain it was the long one bud. I hope this solves your issues Thumbs up
BLACK RALLYE - Sold
Posted 24th Feb 2018 at 21:06
It was the long one. Thumbs up
Posted 25th Feb 2018 at 16:37
3rd time lucky
quote:
[quote="stan_306gti6"]It was the long one. Thumbs up
Thanks for clarifying Stan. You know how bad my memory is Thumbs up
BLACK RALLYE - Sold
Posted 25th Feb 2018 at 18:37
aircool
blandy wrote:
Diff?
How strong are the standard diffs?
Just had a shaft replaced and im getting grinding/banging when accelerating with steering lock on, slightly worried!
Posted 1st Sep 2019 at 12:30
did it make the noise before the new shaft?
Posted 1st Sep 2019 at 15:28
aircool
Negative, ferried it to the garage who tested and found that the new (recon) shaft had an inner joint failure. This was subsequently replaces again and this has also had the same failure. The inner joint popped out again. Beginning to think if there is something else at play or these shafts are too short or really bad luck?
Posted 3rd Sep 2019 at 18:23
just poor quality by the sound of it, the only shorter shaft I can recall that would fit hub and box are 309 which would be obviously way too short
Posted 3rd Sep 2019 at 19:22
