Innes drummond
Author | Subject: Radio |
inzomatic
Regular Location: alloa Registered: 10 Jan 2013 Posts: 157 Status: Offline |
Put the original CD player back in the pug recently put code in but it asks for it every time I switch it on any help would be great I know there's a fuse can be moved but can't remember where ________________________________________ Innes drummond |
Posted 27th Sep 2017 at 20:39
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 389 Status: Offline |
Could be that ignition+ and battery+ were switched before so the original radio cannot store its settings. |
Posted 28th Sep 2017 at 08:36
inzomatic
Right I changed the battery over a while ago when I had a different head unit in it is there no way of storing the settings and getting the radio to come on with ignition ________________________________________ Innes drummond |
Posted 28th Sep 2017 at 09:35
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,817 Status: Offline |
wont be a fuse if its actually working, there's a missing permanent live, check the wiring, may even be a fuse on the back of the unit.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 28th Sep 2017 at 10:31
inzomatic
Ok will check that ,is there not positions in fuse box that determine if head unit comes on with ignition ?________________________________________ Innes drummond |
Posted 28th Sep 2017 at 10:37
inzomatic
I have to switch the radio on after I've turned ignition ________________________________________ Innes drummond |
Posted 28th Sep 2017 at 10:39
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
You need to swap the ignition and permanent lives over.They are wired the wrong way round. ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
Posted 28th Sep 2017 at 15:59
inzomatic
What do you mean ? ________________________________________ Innes drummond |
Posted 28th Sep 2017 at 23:49
Ben_W
You will have two live connections going into the stereo from the wiring loom. One is from the car battery, known as the permanent live. This helps your headunit store security codes, station presets, settings etc. it also allows you to turn the radio on when the ignition is off.The other is an ignition live. Comes on with the ignition, hence why your radio turns on with ignition on. These two.are the wrong way round (a very common issue..) Swap the wires around. Should fix everything. ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
Posted 29th Sep 2017 at 00:44
inzomatic
When I first got the car the original radio was in it and it came on fine so surely if the wires wer the wrong way that would be happening when I first got it also it's two connector blocks that go into the back of the radio so how can they get mixed up?________________________________________ Innes drummond |
Posted 30th Sep 2017 at 09:39
miki4
You can cut and resolder the wires or swap the pins in the connector if you're wily. But if that did not happen already sometime before and the original radio worked correctly there must be another reason. First check if there is permanent live (12V) on the yellow cable's pin in the connector and switched live on the red cable (12 V if ignition on and 0 V if ignition off). |
Posted 30th Sep 2017 at 16:02
mik
Seasoned Pro Location: Kent Registered: 17 Feb 2011 Posts: 2,100 Status: Offline |
I've just installed a remote stalk adapter loom so I can operate my Balupunkt radio with the OEM remote stalk, and after installation of the loom this has happened to me also. Unlike before I can't switch radio on when the car is off and I also need to switch the radio on every time I start the car. I'll need to remove the loom and swap these wires around as stated. ________________________________________ Cherry Rallye SOLD |
Posted 1st Oct 2017 at 12:55
