Author Subject: Installing a starter/ignition panel
Flatoutfarr
Alright learned forum members.
I have decided to install one of these panels in my 306 race car so I don't have to have the steering lock and standard ignition key switch on the side of the steering column.
Have any of you 306 racers/track day guys done this?
Do you have a wiring circuit I could have? My 306 GTI-6 is a T reg [1999] one. Although I have the Haynes manual for the 306 I know that the GTI-6 is not covered in it.
I already have the FIA emergency cut-out switch on the centre dash.
Thanks for your help.
Adventure before Dementia !!
Posted 10th Aug 2017 at 16:39
jeffers Forum Admin
I've done what I think your trying to do, I fitted a toggle switch ignition and push button starter. It's quite easy really, I got my hands on another ignition switch , worked out the wiring labelled it then removed the loom from the ignition switch and fitted it to the switches accordingly. Il have a look round and see if I can find my notes from when I did it.
Team Running Engine again!
Team Negative Camber!
Posted 13th Aug 2017 at 14:17
Flatoutfarr
Cheers. I have had a look in my 306 Haynes manual at the wiring and seen new ignition switches for a 306 on e-bay and thought I may try cutting into the wiring to install this.
If an enthusiast like you has already done this and you have the wiring circuit, I would be very grateful.
I have found the 306 GTI forum excellent for shared info.
If you PM me I will give you an e-mail address to send me a pdf of the wiring layout.
Posted 13th Aug 2017 at 16:00
gnrlee
i'd like to do this too!
often thought about fitting a modern land rover push start button (like the feel of them! LOL) and hiding it when the track car gets nearer to being ready just little added security and I want to do away with keys! Razz
Search Button
Freelance 3D & Graphic Designer Looking for work!
if you want to have a look at some of my other work My Blog!
Contact me at dw.3dgraphics@gmail.com
Posted 13th Aug 2017 at 19:44
Flatoutfarr
quote:
[quote="jeffers"]I've done what I think your trying to do, I fitted a toggle switch ignition and push button starter. It's quite easy really, I got my hands on another ignition switch , worked out the wiring labelled it then removed the loom from the ignition switch and fitted it to the switches accordingly. Il have a look round and see if I can find my notes from when I did it.
Hi
Any luck with that wiring diagram you were talking about?
Posted 1st Sep 2017 at 18:17
jeffers Forum Admin
Hi, I've not got a diagram but I can draw one. I'll try knock one up over the weekend! Along with a few pics of the set up.Thumbs up
Posted 2nd Sep 2017 at 09:08
You are not able to post as you are not a member.
If you would like to upgrade your membership, please read the Membership section.
Pug1Off
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2018 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
