How do i fix this little issue
BLACK RALLYE - phoenixWHITE RALLYE - valliant
Author | Subject: Fuel gauge fault |
mocinim
Seasoned Pro Location: The Darkside of bedford :) Registered: 09 Jan 2015 Posts: 2,307 Status: Offline |
Hi gents have a fuel gauge issue it wont drop down past just under the quater even when its empty its not the fuel pump its self as ive just changed it (yes it was like it before the change )How do i fix this little issue Cheers ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Posted 13th Jan 2017 at 17:13
demondriverdan
Have you got a spare set of clocks you could put in to see if the problem is there?________________________________________ Rallye Race Car |
Posted 13th Jan 2017 at 17:15
mocinim
No unfortunately not am after what it could be all ideas really so i can go through an eliminate etc So you think it could just be the clock ?? Gauge ! ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Posted 13th Jan 2017 at 17:17
mocinim
Any other ideas gents ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Posted 15th Jan 2017 at 13:40
demondriverdan
I had a fuel gauge issue ages ago and it turned out to be the clocks, put another set in and it just worked. Just wanted to let you know it was a problem I had had in case you hadn't thought about it ________________________________________ Rallye Race Car |
Posted 15th Jan 2017 at 15:45
mocinim
I will give it a go cheers dan________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Posted 15th Jan 2017 at 16:28
ale624
Regular Location: bristol Registered: 02 May 2016 Posts: 173 Status: Offline |
Anyone know the specs for the voltage on the fuel level sensor wire? You could check that with a multimeter at the clocks? |
Posted 15th Jan 2017 at 17:56
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,593 Status: Offline |
Swap the clocks over with your other one easily done without removing steering wheel :-)________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
Posted 15th Jan 2017 at 18:30
mocinim
Can the fuel gauge be removed individually or is it a clock change dash thingI would like to keep my original dash etc ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Posted 15th Jan 2017 at 18:53
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
Posted 15th Jan 2017 at 19:07
cully
have you messed with the needles on the clocks? have you pushed them on to far scrapping the backplate |
Posted 15th Jan 2017 at 19:04
mocinim
No not been in there will get it open and see if i can spot anything worst comes to worse ill re soldier a new motor cheers cullyProbably needs a clean or a dryjoint has occurred ________________________________________ BLACK RALLYE - phoenixWHITE RALLYE - valliant http://public.servicebox.peugeot.com/ https://www.gov.uk/check-mot-history |
Posted 15th Jan 2017 at 19:53
