Author Subject: Pre loading coilovers
pugheaven
So just fitted my new suspension and want to reassure my self on a few things.
I take it you set up pre load of the spring with weight off the car?
Iv read a few articles saying that 5mm preload load is about right?
I know when I get the car corner weighted it will be adjusted but as a starting points are the above correct?
Posted 30th Dec 2016 at 12:03
pugheaven
Posted 30th Dec 2016 at 19:00
barrym
What are you using? The only spring adfjustment on mine is ride height. Pics would help.
Black Rallye occassional toy
Posted 30th Dec 2016 at 20:22
pugheaven
Bc coilovers, you set the preload by adjusting the collar at the top and lower the car by winding the body into the housing
Posted 30th Dec 2016 at 21:15
pugheaven
Posted 30th Dec 2016 at 21:17
barrym
Gotcha. Yes set up off the car. Assuming you want to use the initial spring rate then just take up the slack.
Posted 30th Dec 2016 at 21:26
aaron6
I always thought the preload only mattered with helpers.
Posted 2nd Jan 2017 at 16:48
craig903
unless there is a nut to stop that top spring cup and spring from lifting up then all your doing is changing ride height?
208 GTI Owner
Posted 2nd Jan 2017 at 19:14
pugheaven
Clearly I put the top mount on first, then done the collar up so the spring was tight then wound the collar up a further 5mm
Posted 2nd Jan 2017 at 22:15
Just enough to take up the slack in the springs mate yes if you have separate height adjustment too rather than using preloaded for height adjustment like most do. Just so
To stop the springs rattling around. Obviously once corner weighted they will all be adjusted and the ride height will need resetting to compensate.
Posted 6th Jan 2017 at 13:37
You ~10mm minimum just to make sure the springs stay seated through vibrations.
Posted 6th Jan 2017 at 16:46
