Post #1111
clen666 wrote:I'm impressed
Thank you
I really would say if they weren't brilliant & they are as stiff & flex less even at the top that gets bent out by thiefs less than my Metal ones with nothing cut out ...only small issue is getting the Hinges height 95% correct ...the distance between is easy but because no marking for them to go anywhere unlike the lock side ...and you don't have much movement to ajust them up & down ...only side to side !
I did make & take a template off original doors ...but as I've said in the earlier post I was out on both hinges by 5mm ...
The square Alloy block you can't see until you drill the holes that's sandwiched between the Kevlar is so thick & ive had to use x4 -45mm bolts to go through hinges & door thickness which I'm so pleased about ...
Now I've got the passenger side spot on I'm making a template for these doors only to reverse & sort drivers side out ..
I've contacted Tony Palfrey of Maxi Motorsport who supplied them & he's really pleased how they fit ....he's never supplied a pair of these in Kevlar before & it's always great to know what your selling Quality wish
The lock picture below is was all marked out by the manurfactures so easy Dremel cutout job
I'm really hoping to get them sprayed & as with my fibreglass bonnet & tailgate not be able to see they aren't Metal ....which shows how good they are made & sprayed
