Author | Subject: Day666 / 6 updates / 1% road 99% track/Race |
Seasoned Pro Location: Bristol Registered: 20 Apr 2013 Posts: 5,206 Status: Offline |
Post #1076
Front Ashtray / handle viewDay666 has attached the following image: |
Posted 3rd Mar 2017 at 18:40
Post #1077
All formed Day666 has attached the following image: |
Posted 3rd Mar 2017 at 18:41
Post #1078
Designed to fit the doors 100% Day666 has attached the following image: |
Posted 4th Mar 2017 at 22:46
blandy
Post #1079
Posted 3rd Mar 2017 at 19:14
clen666
Post #1080
They look great Where does the interior handle go? You just have to cut a piece out where you need it? ________________________________________ Team 'unintentional rat look' |
Posted 5th Mar 2017 at 11:28
Post #1081
clen666 wrote: They look great Where does the interior handle go? You just have to cut a piece out where you need it? Thank you Blandy Clen666 yes m8 they leave everything on the door & inside Carbon door panel for you to cut out ...the hinges are going to be fun to do |
Posted 5th Mar 2017 at 13:06
clen666
Post #1082
Ha yeah I'm sure they will!Interested in a set of those eventually ________________________________________ Team 'unintentional rat look' |
Posted 5th Mar 2017 at 14:48
Chr1sch
Seasoned Pro Location: Worcester Registered: 02 Aug 2014 Posts: 1,025 Status: Offline |
Post #1083
Wow they look amazing! |
Posted 5th Mar 2017 at 18:32
Post #1084
Chr1sch wrote: Wow they look amazing! Thank you ...The pictures don't really do them justice but I'm not looking forward to test dry fitting them....no hinge locations |
Posted 6th Mar 2017 at 14:07
superchargedblack1997gti6
Post #1085
Will those door cards fit a standard door Damien?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
Posted 6th Mar 2017 at 15:39
Post #1086
superchargedblack1997gti6 wrote: Will those door cards fit a standard door Damien? Yes Ross they will m8 |
Posted 6th Mar 2017 at 18:21
Chr1sch
Post #1087
What did you do with your window switches in the end Damien? Gone Manual or poly? |
Posted 7th Mar 2017 at 19:32
Post #1088
Chr1sch wrote: What did you do with your window switches in the end Damien? Gone Manual or poly? I had winders on my standard doors Chris .... I have had to order horrible hard shell Polycarbonate door windows ...sadly new doors only use them ...but I'm have Tony of Maxi Motorsport get scoops put into them ...this will help with getting cold / cool air into the car better when the small rectangle openers are slid open |
Posted 8th Mar 2017 at 18:10
clen666
Post #1089
I assume that polycarbonate windows designed for the standard doors fit these doors, yes?No need for specialised ones? ________________________________________ Team 'unintentional rat look' |
Posted 8th Mar 2017 at 19:37
Post #1090
clen666 wrote: I assume that polycarbonate windows designed for the standard doors fit these doors, yes? No need for specialised ones? These are slightly different size & Bolt on Standard ones could be cut & drilled but I'd rather get the correct ones for a few pennies more |
Posted 8th Mar 2017 at 21:42
Chr1sch
Post #1091
Pm me if you're getting rid of your window mechanisms chap :-) |
Posted 9th Mar 2017 at 07:27
clen666
Post #1092
Day666 wrote: clen666 wrote: I assume that polycarbonate windows designed for the standard doors fit these doors, yes? No need for specialised ones? These are slightly different size & Bolt on Standard ones could be cut & drilled but I'd rather get the correct ones for a few pennies more Hmm ok, just I was planning on buying a set of P4P windows but might have to hold off on those if they aren't going to be a straight fit ________________________________________ Team 'unintentional rat look' |
Posted 9th Mar 2017 at 11:00
Post #1093
clen666 wrote: Day666 wrote: clen666 wrote: I assume that polycarbonate windows designed for the standard doors fit these doors, yes? No need for specialised ones? These are slightly different size & Bolt on Standard ones could be cut & drilled but I'd rather get the correct ones for a few pennies more Hmm ok, just I was planning on buying a set of P4P windows but might have to hold off on those if they aren't going to be a straight fit Contact Tony Palfrey @ Maxi Motorsport email only .... His come from abroad |
Posted 9th Mar 2017 at 12:04
clen666
Post #1094
Ok thanks________________________________________ Team 'unintentional rat look' |
Posted 9th Mar 2017 at 13:17
blandy
Post #1095
clen666 wrote: Day666 wrote: clen666 wrote: I assume that polycarbonate windows designed for the standard doors fit these doors, yes? No need for specialised ones? These are slightly different size & Bolt on Standard ones could be cut & drilled but I'd rather get the correct ones for a few pennies more Hmm ok, just I was planning on buying a set of P4P windows but might have to hold off on those if they aren't going to be a straight fit Surely there made to the same dimensions as a normal steel door so cant see why a poly window wont fit as you would do on a normal door |
Posted 9th Mar 2017 at 13:54
Post #1096
blandy wrote: clen666 wrote: Day666 wrote: clen666 wrote: I assume that polycarbonate windows designed for the standard doors fit these doors, yes? No need for specialised ones? These are slightly different size & Bolt on Standard ones could be cut & drilled but I'd rather get the correct ones for a few pennies more Hmm ok, just I was planning on buying a set of P4P windows but might have to hold off on those if they aren't going to be a straight fit Surely there made to the same dimensions as a normal steel door so cant see why a poly window wont fit as you would do on a normal door Can only tell you what I'm told ...but the OE door glass goes down inside the door a fair bit & mine sit on a lip either bond or bolt ...so not so tall as OE ,...they are polycarbonate hardshell Margard not from P4P U.K. But screen printed |
Posted 9th Mar 2017 at 14:19
demondriverdan
Post #1097
Clen, if you do end up buying the window kit from Maxi Motorsport, let me know how it is. I've been eyeing it up for the race car as well just need to get funds together________________________________________ Rallye Race Car |
Posted 9th Mar 2017 at 17:58
clen666
Post #1098
demondriverdan wrote: Clen, if you do end up buying the window kit from Maxi Motorsport, let me know how it is. I've been eyeing it up for the race car as well just need to get funds together Will do mate, but don't hold off waiting for me as I'm in the process of rebuilding my garage which is costing more than I'd anticipated, so might need to save up for a while! ________________________________________ Team 'unintentional rat look' |
Posted 9th Mar 2017 at 20:31
Post #1099
Just to update you guys ...I'm having on the doors the fixed thermally formed screen printed Hardshell Marguard both sides with opening smallish McDonalds Big Mac size sliders & air scoops ...so when the sliders are open the scoops will direct maximum cool / cold air into the car & closed keeping any water etc out ... I'm having The same but no openers or scoops on the rear quarters .... Both will be lightly bonded & bolted for 100% Saftey ... Also I'm sending Tony a template of my door windows to get 100% pattern .... Hope this helps NOT from P4P |
Posted 9th Mar 2017 at 22:45
Post #1100
I've made a 5mm Polycarbonate (template) for both the front door windows & they are 0.460 at highest peak & 0.920 at widest point ...this way they will be made 100% spot on Hope this helps guys Day666 has attached the following image: |
Posted 10th Mar 2017 at 18:44
