Post #43
Well this weekend was mostly successful, being that I got the car on the trailer down to my mates workshop to get the screens both fitted, and the exhaust finally sorted out (cut about a 4" section from the downpipe, refitted the flange at the end and welded up - also welded a lambda boss in).
Had chance to get it running properly and can happily confirm everything's running fine it seems! Gauges all seem to work, the RPM hits maximum as I start it but settles to the right RPM afterwards (did the tacho-solder mod instead of the coilpack one)
Only thing I noticed is the oil pressure sensor threaded T piece leaking a bit so will try to resolve that
Also, on the standard gti6 setup, pulling the brown thermostat switch out triggers the fans at full speed. On mine, it's not doing anything, but the temperature didn't get remotely warm anyway.
With that in mind, I'm running the diesel twin-fan setup with the proper relays etc. Anyone know if it should still trigger it? I know the fans work as I tested them before fitting them. Just didn't want to let it get hot before them kicking in and relying on the temperature gauge for the first time.
The only downside to the weekend is I smashed my freshly fitted and painted front bumper to bits on the edge of the trailer after a little incident with the winch. So need to get a new one and get it painted up
Happy though overall that it runs and drives! Quite juddery at low rpm in first but I think it's more of a solid-mount vibration rather than clutch issue.
Bit unsure about the rear centre section heatshield that runs under the fuel tank. Does that bolt to the bracket that wraps around the beam? (The one I vividly remember throwing in the bin!)
Pics..
306 rallye reproduction decals (
full sets/
individual decals) |
306 b-pillar textured vinyl weatherstrips
306 slam panel esso stickers |
306 yellow / orange / pension fund red side door badges
gti6 inlet manifold badges |
306 rear boot badges (p2/p3)
