Merlin are a official dealer ...but you never know Chris ??
You sure you don't have the metal zinc silver Extreme ones ?
These alloy Red ones are poo !!!
I'm ringing Aero up tomorrow
displaying posts 26 to 45 of 45
Pages (2): 1 [2]
Author | Subject: Which Direction Aero catches best on 6 bonnet |
Seasoned Pro Location: Bristol Registered: 20 Apr 2013 Posts: 5,209 Status: Offline |
eddy_gti6 wrote: Were they genuine aerocatch ones? The ones i have had twist and bend and never snapped Merlin are a official dealer ...but you never know Chris ?? You sure you don't have the metal zinc silver Extreme ones ? These alloy Red ones are poo !!! I'm ringing Aero up tomorrow |
Posted 12th Apr 2015 at 22:26
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,817 Status: Offline |
if you had marked and drilled accurately you shouldn't need to bend them.... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 12th Apr 2015 at 22:31
welshpug! wrote: if you had marked and drilled accurately you shouldn't need to bend them.... Mei stop it Passenger side 100% spot on & drivers side was just catching 1-2mm ....one little rubber mallet tap for perfection & crack appears ? Not a problem ... |
Posted 12th Apr 2015 at 22:45
eddy_gti6
No mine are the red alloy ones. Just drill your hole bigger, the big washers and nuts will hold it in place! Here if you need one mate. Think i have a few________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
Posted 12th Apr 2015 at 22:49
Seasoned Pro Location: DoncastAAAAARGH Registered: 13 Jan 2008 Posts: 4,637 Status: Offline |
demondriverdan wrote: Has anyone got photos of how they have attached them for the boot? I think theres a few pics somewhere in my project thread. ________________________________________ Goldie the track car. |
Posted 13th Apr 2015 at 06:50
How brilliant are AeroCatch UK ...Rang them up & spoke to a chap called Graham & two (steel) not alloy ...Extreme Strike pins on the way to me FOC today .... Makes sense what he said if everything is to stiff & strong it passes the impact downwards to another location . So they are designed to break !!! I shouldn't of tapped them with a small rubber hammer though |
Posted 13th Apr 2015 at 12:45
Big thank you Aerocatches for these free plated steel extreme bonnet spikes !!Day666 has attached the following image: |
Posted 15th Apr 2015 at 06:44
Need a pair of these for my new carbon skin bonnet. Looks like I'll be going for the "extreme" ones then if the red ally ones are made of cheese....Could people put up some pics of where they have mounted them from top amd bottom and the slam panel please? Presume the kit comes with a template? ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 26th Jul 2016 at 21:19
demondriverdan
My ally ones on the bonnet seem ok although I did get steel ones for the boot________________________________________ Rallye Race Car |
Posted 26th Jul 2016 at 22:08
Post #35
The red ally ones are fine so long as they're used correctly. They only started using the extreme ones because Milners kept breaking the bonnets loose - but then the clamshells weigh about 30kg each and keep bouncing off trees so....________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
Posted 26th Jul 2016 at 22:37
Post #36
Thread bump....I've just bought some "extreme" aero catches with the steel pins onto cheese aluminium ones and will be looking to fit them shortly. Where's best to mount them on the bonnet / slam panel and which way round? As Damien has or other way round by 90 degrees? Anyone got any pictures or an opinion as to which way works best? Itching together a carbon bonnet back on the car now. ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 19th Feb 2017 at 15:43
demondriverdan
Post #37
On the race car I drilled out the rubber bungs on the slam panel and mounted the pins there. If it's any use, you're welcome to come over and take measurements?________________________________________ Rallye Race Car |
Posted 19th Feb 2017 at 16:03
RetroPug
Post #38
By rubber bungs do you mean the height adjustment things? They just wind out, no need to drill. At least on a p.1 they do.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Posted 19th Feb 2017 at 16:32
demondriverdan
Post #39
Yea, those things. It was so long ago I did it I can't remember exactly what was needed ________________________________________ Rallye Race Car |
Posted 20th Feb 2017 at 09:15
Post #40
I shouldn't really need measurements thanks mate will just measure it out myself from a suitable place on the slam panel to an even point on the bonnet each side. More thinking though it says to mount them as Damien has with small end facing forwards I'm more inclined to mount them Accross the face of the bonnet instead as I much prefer how it looks for one thing and they won't be the only thing holding the bonnet down as the carbon bonnet I have still retains the standard bonnet catch but it's only a few screws into carbon fibre that hold the latch part on. Thought I best add the aero catches too as the car goes over 100mph far too easily. Don't want it flying off at speed ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 22nd Feb 2017 at 17:06
3rd time lucky
Seasoned Pro Location: maidstone Registered: 23 Apr 2007 Posts: 1,878 Status: Offline |
Post #41
There are some holes in the slam panel already which line up perfectly with where you need them. That's what I used and I've been over 100mph with no problems at all.I would be more concerned with your centre latch though as when I ONLY had the outer catches, anything above 50mph, the bonnet was flapping faster than a pornstars snatch in a 100 strong gangbang. ________________________________________ DIABLO GTI-6 - Legend - NILE GTI-6 - SoldCHERRY GTI-6 P1 SUPERCHARGED - Broken up BLACK RALLYE - Sold 205 Dturbo xud9 work horse - Dead CHERRY RALLYE - new toy |
Posted 22nd Feb 2017 at 19:05
Post #42
Yours is just a very thin fiberglass skin so unsurprising it flapped in the breeze I'll have aero catches and centre catch and bonnet has a full proper carbon frame too so a lot more solid than your one but still surprisingly weighs f**k all. Must be half of what my other carbon bonnet weighs ________________________________________ Black power baby! SUUUUUPERCHARGEDSeat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
Posted 22nd Feb 2017 at 19:26
3rd time lucky
Post #43
Cool story bro.________________________________________ DIABLO GTI-6 - Legend - NILE GTI-6 - SoldCHERRY GTI-6 P1 SUPERCHARGED - Broken up BLACK RALLYE - Sold 205 Dturbo xud9 work horse - Dead CHERRY RALLYE - new toy |
Posted 22nd Feb 2017 at 20:27
Post #44
My single skin carbon kevlar bonnet flapped around loads with just aerocatches in the corners, so I added an extra in the middle at the front which made it better. I then added some ally flat strips which stiffened it up no end. One of the nuts came off on one corner at 80mph causing the bonnet to fly up, ive never hit the brakes so hard! ________________________________________ Goldie the track car. |
Posted 22nd Feb 2017 at 20:40
demondriverdan
Post #45
I changed the bolt that holds the catch mechanism on to be much longer and then made a hole in the bonnet badge so the bolt pushes through it and stops the bonnet flapping. Only works for me because I don't have hinges as the whole bonnet is removable.________________________________________ Rallye Race Car |
Posted 23rd Feb 2017 at 08:32
Pages (2): 1 [2]
