Author Subject: Driveshaft Bearing
bruce2007
Just wondered if anyone could give me an idea how to get the bearing off in the middle, I might be being thick but I'm at a loss.
bruce2007 has attached the following image:
Posted 23rd Apr 2014 at 10:56
a long puller and some heat.
you need to shift the retaining collar first.
Posted 23rd Apr 2014 at 11:03
alcon
is the puller to get the collar off I take it?....does the bearing then just slide off or does that need pulling as well?
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 29th Mar 2021 at 23:38
both will need pulling, might be able to do it with a press instead of a very long puller, but you'll need the jaws of a bearing puller to go behind it
get it all set up and under pressure and warm up the collar with a mapp torch.
use a length of tube to press the bearing into place, you can then heat the collar and drop it on.
bearing is a common side, 6006 from memory, 30x55-13
Posted 30th Mar 2021 at 19:32
alcon
thanks, I'll try that. You're correct about the bearing size....30x55-13 (or part no. 3247 03). SNR also do one which is part no. 6006.
1999 Rallye (black)
Posted 30th Mar 2021 at 20:58
The Peugeot GTi-6 & Rallye Owners Club Ltd - Registered in England & Wales - Reg No: 07410694 - ©2021 all rights reserved.
Please Note : The views and opinions found herein are those of individuals, and not of The Peugeot 306 GTi-6 & Rallye Owners Club Ltd or any individuals involved.
No responsibility is taken or assumed for any comments or statements made on, or in relation to, this website. Please see our updated privacy policy and legal information
