Members Traders Members Leaderboard Forum Search Help
Home Forums Wheels / Tyres MOMO Arrow refurb project - part 2 underway (pic warning!!!) Add a more detailed reply Start a new thread in the Wheels / Tyres forum
displaying threads 1 to 12 of 12
Author Topic: MOMO Arrow refurb project - part 2 underway (pic warning!!!)
xav
i think its time to show you all how far ive got with my wheel refurb Smile
the story began when i got hold of a set of MOMO Arrows complete with pirelli runflats for £50 from a guy that robert knows through work. the original idea was to refurbish a set of cheap wheels which had miner damage around the edge of the rim which i would sell on afterwards. i thought the whole process would be reasonably easy but i was wrong.. very wrong. after recieving the wheels one by one for about 2 months i knew that this was not going to be easy.
they were badly damaged and extremely dirty and as far as i know, had been fermenting in the back of someones garage for a long time. oooooo nooooo!
a couple of snaps of what they looked like when i first got them and gave them a ligh clean with some wipes. apologies as they were taken by a webcam..
these pics dont show the full extent of the damage. one of the wheels was completely covered in brake dust and dirt which wouldnt come off even with brillo pads and another had two very large chips almost as if it was hit with the sharp end of a hammer. one was 4mm by 6mm deep and the other around 7mm by 4mm Blink
Part 1
after reading various refurb threads, i decided to use fibreglass to fill the gaps. its the same stuff that squiff used only with a different name
the first thing i did was give the wheels a really good clean to remove all the crap. ITS IMPORTANT THAT THEY ARE AS CLEAN AS POSSIBLE! obviously not every single bit of dirt will be romoved but the more the better.
the next thing was to sand down the wheels to remove the old lacqeur and most of the original paint so the new primer will stick. you can see how the tyre machine i used has damaged the back of the wheel so this was a difficult part to sand down.
half way there Smile
be sure to clean the wheel after sanding it down!
at last it was time to use the filler! it is a lot easier to use something to mix the filler on. in this case i used a dirty great slab of mdf
as you might know, this stuff is savage so id recommend some gloves to prevent it ripping some skin off.
after it dries, (20-60 mins) sand down the filler to take the original shape of the alloy. i used a file to remove the rough spikey stuff then the "mouse" from bosch. honestly, using a small electric sander makes a really big difference!
a very rough grade of sand paper was used here. i found it stuffed into a cupboard in my grandads garage.
also this stuff gives off tonnes of dust so i used a face mask to stop me getting high. it helps a lot as you end up covered. luckily ive got some overalls aswell Laugh
rough stuff gone. wheels starting to look round again :cool
i also tried to smooth the centre caps but because they are made up of two separate pieces, the plastic and the big centre bit, the filler started to crack around the edge because of the flexing so i scrapped the idea
primer time!! after a trip to halfrauds one weekend i ended up paying a fortune for 2 tins of filler primer, one tin of grey primer and some 1500 grit wet an dry. ive been told that it works quite well
yellow is the new silver Ninja!
now, the eagle-eyed may notice the imperfections on the edge of the rim and the centre of the wheel in the next few pics. this was caused by tiny chips in the filler which are really only visible when the primer is on. you couldnt feel them when sanding as the dust had gone into the holes. they can be filled again after primer
to summarise whats happened so far:
  • clean the wheel as much as possible with whatever youve got to use
  • sand down the wheel using a rougher grade of paper working your way up to around 400 grade
  • fill the wheel using the filler of your choice using a fair amount just to make sure all the gaps are filled
  • sand down the filler using the rough stuff again and work your way up
  • clean the wheel off again ready for filler primer
  • dont whatever you do, pile the filler primer right on. use light strokes and build up light layers sanding lightly in between layers to remove dust and particles that may have stuck to the wet primer. if at any time it decides to run, let it dry then sand it back out flat.
  • after it drys, give the wheel a good look over for imperfections and wipe off the dust that came off.
    thats all i have for now. i will be going back down on monday 21st to finish off the filler primer then continue with the normal primer.
    when i finish painting the wheel ill include a list of all the things i bought, where i bought them and how much they cost. ive only been working on one wheel and have spent £90 overall in the last few months as ive been doing them one or two days every 4 weeks
    so what do you guys think so far? not bad for a 16 year old Big grin
    ____________________
    2003 106 Quiksilver progress >> here - photobucket album >> here
    the forum child.. bye bye provisional!!
    jolly boy john wearing his ma's shoes on his feet and all his dads shoes doon his pants and shoutin squirrels all the time is FOR REAL!!.. FOR REAL!!
  • Posted Mon, 13 Jul 09 19:35  | Profile
    Status: Online
    Dont waste you time with the alloys mate,do what i was doing when i was 16,getting f*cked up off cheap cider Thumbs up
    More fun than refurbishing wheels! Laugh
    Seriously mate,top work and keep it up! Smile
    Team Black Rallye Love
    Posted Thu, 21 May 09 23:19  | Profile
    pugpete
    Bloody hell good work mate!
    Ex Black phase 2 GTi6(now dead)
    Ex Sigma phase 1 GTi6(sold on)
    Now in a low,slow,dented and dirty 306 Estate and a Jacked up P38 RangeRover.
    Posted Thu, 21 May 09 23:17  | Profile
    mark-house
    Top work very nice finish you got to the shape. I would never have thought of using fibre glass filler to do the curbed edges.
    Peugeot 306 GTi 6
    BMW 320 td compact M-sport
    1967 Mini Cooper
    1990 Jaguar XJR 4.0
    Posted Thu, 21 May 09 23:28  | Profile
    chrisd306
    if you had met Xav, you would no that buying cider wouldnt be easy, unless his big bro Robert1980 bought it for him!!
    Good effort, ave nae patiance to refurb wheels!!
    SCRallye,GTi6 & a Dturbo s = I Live For The 306
    Posted Thu, 21 May 09 23:58  | Profile
    ken
    love it mate good thread! well done
    Team Black Rallye Big grin
    xbox live - Xx 7 kenny 7 xX
    Posted Fri, 22 May 09 17:25  | Profile
    xav
    forgot to mention that that the rim on the back of the wheel hasnt been filled because it isnt visible when its on the car. its wasnt that bad to start with anyway and ive just sprayed right over the top of it. the reason for leaving it was that it would take up more time and i really couldnt be bothered doing it at the time aswell
    edit* lol at chris. funny enough im having a few the now after todays game. twas a fooking great result
    Posted Sun, 24 May 09 23:24  | Profile
    xav
    quick update Smile
    finished off the filler primer stage today and began using the grey primer. its important to make sure all the imperfections have been taken care of or repaired as much as poss, if not then you will have some tatty looking wheels. what i did was rub down the wheel using some sort of blue kitchen roll thats kept in the garage to take off the rough stuff but not actually leave sanding marks and i must say it works well.
    next i used some 1500 grit wet and dry soaked in water and lightly sanded the filler primer to get a really smooth finish. trust me, water makes a big difference. afterwards, i used the grey primer in thin layers untill the surface was completely covered then began using the 1500 with water again to get the decent finish.
    you can see that i have left the bit where the tyre would be. the reason is that it would be a waste of primer and paint by covering a part of the wheel that isnt visible when on the car.
    after a trip to halfrauds with granda and some arguing about what shade of primer i used i opted for pugs own bianca white for the wheels Big grin
    well thats all i have for now. next year ill start painting the wheel and eventually finish it Doh!
    Posted Sun, 12 Jul 09 19:59  | Profile
    xav
    i forgot to mention that there is a mark next to the word and some around the letters in MOMO on the side of the wheel due to crappy filler primer work which i didnt see until i started using the normal primer. i think i used far too much and it went spongy underneath when pressure was applied. the filler itself must have also been uneven as you can see some marks which look like scratches.
    i will try and get a pic the next time im down. its barely noticeable and the cam will probably not pick it up but up close you can see it.
    Posted Mon, 13 Jul 09 19:47  | Profile
    rich-6
    Use the tyre machine so it grips on the outside of the rim it doesnt have jaws like it does for the insides Wink
    Any man who uses a gas BBQ has a vagina.
    f**k off bag of charcoal - check.
    Five litres of petrol - check.
    Matches - check.
    Cool
    RIP Pete Sims
    Posted Mon, 13 Jul 09 20:49  | Profile
    xav
    i know. i realised that my works machine has plastic inserts so it can hold the edge rather than ruin the back. at least its there and not on the front.
    Posted Mon, 13 Jul 09 22:01  | Profile
    html code is disabled
    forum code is enabled
    TPW Engineering Automotive Services
    Contact Us | GTi-6 Owners Club
    All material property of The GTi-6 Owners Club unless otherwise stated.
    Please Note : The views and opinions found herein are those of individuals, and not of the Peugeot 306 GTi-6 & Rallye Owners Club or any individuals involved in this website. No responsibility is taken or assumed for any comments or statements made on this website.
